Home > Maintenance & Mods (L322) > Rear Wiper
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Rear Wiper
When checking my rear washer jets I noticed that the arm of the rear wiper appear to be rubbing on the spoiler where the arm has a kink and this is what I think is causing the cluncking noise when it returns to the rest position. Is there a way to adjust the fitment so that it is lower other than take it of and just try and bend it. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #247775 12th Mar 2014 2:22pm
stu
the spoiler is on a key slot type fitment on the roof and there is scope to pull the spoiler back and forth before tightening the three securing nuts in the upper tailgate.
I have done this and also replaced the wiper blade with a newer type floppy blade which also has a lower profile. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #247827 12th Mar 2014 6:26pm
More info on this here:
http://www.fullfatrr.com/forum/topic884.html Discovery 4 HSE
Post #247834 12th Mar 2014 6:53pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
On a similar note, My wiper arm's lost its curve and it's all rusty. I was looking at the kit that powerful uk do for the arm, washer jet and blade for £50. Surely there must be a cheaper one out there?
Post #247836 12th Mar 2014 6:55pm
My advice, don't buy cheap rubbish on ebay.
If it were me I'd be asking Dan @ Duckworths Discovery 4 HSE
Post #247837 12th Mar 2014 6:56pm
rej
Thanks I took my trim off and no leaking in the car. I will take off the wiper arm and see if I get water before I get a new wiper arm if I can't unblock the washer jets. There is a difference between knowing your sh!t and knowing you're sh!t
Post #247873 12th Mar 2014 8:04pm
