Home > Duckworth Parts > L322 TDV8 MY2008 |
billcyn Member Since: 20 Oct 2013 Location: Whitby Posts: 56 |
Hi Dan
12th Mar 2014 11:27am |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
Hi
17th Mar 2014 9:19am |
Thanks Dan, but it was the bottom drivers side (Turbo to Intercooler) hose & pipe which I
17th Mar 2014 11:13am |
There are 2 turbo to interclooler pipes. Both exit from the turbo's under the exhaust manifolds. Hence they are almost impossible to see from above the engine. In my case, the short rubber pipe could not be properly attached to the main metal pipe extending forward from the drivers side turbo to the intercooler. This rubber pipe is attached using jubilee clips and in my case a leaking low pressure fuel return from no.1 injector had contaminated the rubber pipe causing it to slip off. LR do not supply the rubber hose as replacement, you have to buy the whole pipe (c. £90 incl VAT). Local stealer charged £322 in total so guess this equates to around 2 hours for the labour.
9th Apr 2014 5:09pm |
RoryM Member Since: 02 Mar 2013 Location: Ireland Posts: 51 |
Thanks Bill, Does any one know if there is there an engine diagram for the 06-09 FF to show this location? I'd really love to see it.
10th Apr 2014 11:16am |
Rory
10th Apr 2014 1:20pm |
