![]() | Home > Technical (L322) > What rating battery charger ? |
You can see in this one how the eyelets are connected up to the car for my ctek
I don't think its intended as an earthing point but more a mounting point but it does earth straight to the body so that provides more than enough for the 5amp charger I have and I think should cope with upto 15-20 for the size of it. Failing that there are some in the lower section of the boot that are used by the towing electrics that you could still use |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
There’s a high current earth at the rear of the compartment just below the fuse panel.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
bit more info on charging from out side of vehicle hear = http://www.fullfatrr.com/forum/topic23501.html
steves025uk Member Since: 24 Oct 2012 Location: London Posts: 52 ![]() ![]() ![]() |
Thanks for all the help everybody. |
If it lies flat on the floor you could use some liquid metal to hold two bolts down to the floor and then drop it ontop of that with some nuts and then it won't rattle around and would have some air around it.
Job done.
RoyMacDonald Member Since: 18 Aug 2014 Location: Rye East Sussex Posts: 8 ![]() ![]() ![]() |
Rear boot 12v socket. Well my MY02 handbook says it's a permanent 12v feed but when I plugged my Ctek into it the Ctek read OK at first but after a short length of time the socket turned off. I'm wondering what the coolbox plugs into? I assumed it was that socket. But that makes no sense if it turns off with the electrics. Are there settings that can be altered for the socket? |
I believe there is a relay somewhere that can change this.
