Home > Technical (L322) > Trans Failsafe Program - Recent Experience |
I was driving round Bath yesterday, up and down lots of steep hills with sharp corners. As a result I was using the manual gears a lot to control descents and to hold gears etc.
5th Aug 2010 12:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
finding out what 'tfp' stands for would help to diagnose the problem |
5th Aug 2010 12:58pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Clue is in the title...
5th Aug 2010 1:05pm |
i see that now....[hangs head in shame.]
5th Aug 2010 1:09pm |
Mapmuppet Member Since: 03 Sep 2008 Location: Guildford Posts: 153 |
Dan, sounds like you need to buy my RR for 13K 2005 Audi A8 W12
5th Aug 2010 1:33pm |
specman Member Since: 20 May 2010 Location: Fife Posts: 250 |
Trans Failsafe Prog on the BMW E38 7 series could indicate a faulty camshaft sensor,knackered gearbox, misfire, VANOS unit issue, replacement gearbox oil filter incorrect type, plus a few other permutations.
5th Aug 2010 2:26pm |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
Sounds more like a one off glitch to me, espeically as it hasn't done it again even when provoked. |
5th Aug 2010 3:02pm |
It's not heat related, I've ruled that out by driving it hard and forcing TC slippage (by appying brake whilst driving). It also wasn't the overheat shift pattern, it was 3rd gear or above only which is the limp home no other gears will work mode. When they overheat they come up with "Trans Overheat".
5th Aug 2010 4:44pm |
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 |
Can you get the fault code read?
5th Aug 2010 6:59pm |
Yeah, I'm going to drop it in for a code session at LR, trouble is I just dont trust them not to try and rape me... |
5th Aug 2010 7:02pm |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
If you're ever near the Dartford tunnel in Kent, pop over to my work & I'll diagnose for you - don't do LR bits so no hard sell |
5th Aug 2010 7:09pm |
If it does show as the above code, which I beleive is a common fault with RR and BMW, then have a read of the following, part was quite straight forward to fit in the end?
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
dan, by any chance have you been messing with your ibus interface before you had the fault.
7th Aug 2010 9:23pm |
Hadn't been fiddling with the iBus that eve, not messed around for a while actually...
7th Aug 2010 10:04pm |
