Home > Maintenance & Mods (L322) > Possible head unit replacement
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Hi guys,
Can any of the more tech/electric savvy members tell if this would or could be a suitable replacement for a FF?
http://www.andrive.co.uk/android_bmw_e39.php
They also offer different model BMW ones that might be a possible replacement if the above one isn't.
Cheers Bushy
2003 RR Vogue Mont� Carlo Blue
Post #246733 6th Mar 2014 8:04pm
probably would be ok, a few members have done these upgrades.. ... - .- -.
Post #246741 6th Mar 2014 8:28pm
Bushy513
It seems like quite a bit of ��$$���� but if it can give you all of the features plus steering controls it might be worth a look. Bushy
Post #246757 6th Mar 2014 9:34pm
Check whether it is only suitable for converting the MID or as a direct replacement for the Vogue non touch screen ? .
Post #246766 6th Mar 2014 10:07pm
Bushy513
They replied to my questions.
 Bushy
Post #247008 8th Mar 2014 8:43am
Oe_tuning
Singapore 2004 Range Rover Vogue 4.4 V8 Epsom Green
I was considering this route too, but I assume we still have to connect our original HU in the glovebox to setup OBC?
Post #247094 8th Mar 2014 3:52pm
Bushy513
Possibly I don't know, unfortunately I can't see a way around it, if you want to keep the computer functions. Bushy
Post #247128 8th Mar 2014 7:58pm
mjdronfield
You can set the analogue clock by resetting the fuse at 12, as that's where the clock goes when power restored........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #247131 8th Mar 2014 8:18pm
If you run Torque Pro (Android App) you can emulate a fair number of the OBC functions plus more besides.... .
Post #247156 8th Mar 2014 10:48pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
Do you know if the HU works with the DSP special amps in a plug and play way?
Thanks.
Post #247196 9th Mar 2014 7:39am
