Home > Technical (L322) > Rear Brake Caliper Question - SOLVED
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Oh boy, seem to be running into a new problem with my FFRR every week.......
Todays problem is:
Had a long run on Monday in heavy rain, got near home and saw white smoke behind. Got home and car smelled of burning brakes (lorry clutch burn type of smell!). The rear off side disc was really hot so I knew it was probably caliper problem as all other wheels ok.
Took wheel off and was surprised to be able to push caliper apart so it hadn't seized, pump the brakes and it moves back and seemed ok. Took for a test drive and same problem. Took wheel off again and took caliper off, brake pads out and liberal coat of copper slip. Checked caliper piston, all moves, seems ok. Took for another test drive and same problem again....handbrake works fine by the way.
Do you think this could be:
A) shagged caliper
B) Problem with the connecting hose (not allowing fluid back through?)
C) Handbrake shoes binding
Any help greatly appreciated, I really love my FFRR but I have had so much trouble recently (rear bushes, stereo, air susp. valve solenoid £550!, air susp. compressor - still waiting to afford that one!) that I'm starting to lose heart......... Big Cry
Also can anyone tell me what to expect to pay for a caliper if it is indeed that and would you replace in pairs?
I have read other posts on this issue but none I could find had the same symptoms exactly......
Thanks all Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #126027 13th Jun 2012 5:52pm
Rear calipers were around £70 each for my TD6, flexi pipes are different depending on the fitting I was around £150 for all 4, but the cheaper ones are around £70 for set of 4
Post #126041 13th Jun 2012 7:20pm
Pedrochellie
UPDATE
Finally solved it -
Clamped the back caliper so it was 'disconnected' and test drove carefully for a few miles and checked disc - all cold, great so it's not a binding hand brake. Then cleaned caliper thouroughily and replaced and test drove again with all working how it should - disc got hot again, damn it! Next replaced the brake hose (£80 with postage Shocked ) bled the system and test drove again - poblem solved - no hot rear disc Very Happy And here we are 2 weeks or so later and all working fine.
Never would have thought the hose could do this!!
Hope this may help someone in the future! Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #128445 29th Jun 2012 5:27pm
How odd?
The same wheel has just started binding on mine with the hub/disk/wheel getting hot and smelling of "Clutch" !
I guess I will have to take wheel off and have a look but for some reason I suspect binding handbrake (Manual Style) any tips on checking this?
Post #246414 5th Mar 2014 10:58am
Pedrochellie
Hi Gaz,
This was awhile ago now but in the end although the hose worked for a few more weeks the same thing happened again - this time I took the caliper off and had it reconditioned and it worked fine ever since. apparently they all seize left rear caliper at some point in their life - who knows why and always the left rear! Bizarre!
My FFRR was sold awhile ago, just couldn't put up with the unreliability and bills.......real shame as boy did I love that motor, and still do Sad
On another note my mate just bought a 2007 TDV8, 94k full service , mint etc etc - two months after turbo goes, sucks all oil out of the engine and the motor is a write off!!!!!!!!
I was planning on buying one of those in the future but that's it, never again after mine and my mates experience - got to be the worst motor on the planet. FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #246442 5th Mar 2014 12:28pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Mine seized on the RHS.....! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #246465 5th Mar 2014 2:19pm
Pedrochellie
Laughing good ol RR Rolling with laughter FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #246498 5th Mar 2014 4:58pm
Mine is also Drivers Side (RHS)
Post #246500 5th Mar 2014 5:04pm
Both mine have seized, cheap pagid one form ecp works fine as a replacement, did mine on the drive. There is nothing that can't be fixed with a hammer😜😜
Post #246510 5th Mar 2014 6:09pm
