Home > In Car Electronics (L322) > Phone connection ?
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Phone connection ?
Is it possible to buy some sort of lead that connect an iPhone to the "phone dock thing " under the centre armrest ?.
Post #245855 2nd Mar 2014 7:16pm
Do you mean the connection in the centre armrest that the Nokia cradle attaches to
Post #245856 2nd Mar 2014 7:23pm
Glynn
Yes, I think thats it.
Post #245857 2nd Mar 2014 7:24pm
I never found anything that would attach to that fitting when i had the 05 Model to an iPhone , had to just use the bluetooth facility in the car ... ====================================
Post #245863 2nd Mar 2014 7:47pm
Glynn
Seems I'm stuck in the middle then since the car is a 55 reg but its the full facelift model ( latest lights, grill/bumper ) & jag engine/6speed box etc but I almost sure no bluetooth.
Post #245866 2nd Mar 2014 7:55pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Mine is a 55 plate and has Bluetooth.
Are you getting your phone to search for the car rather than the other way round?? 4.2 Supercharged Vogue SE
Post #245867 2nd Mar 2014 8:00pm
Glynn
Not sure, its some time since I tried it.
What is the procedure ?.
Post #245868 2nd Mar 2014 8:01pm
Chauch
Just turn the ignition on, got the bluetooth menu on your mobile and search for connections.
If it pops up, enter 2121 and job done.
I thought exactly the same as you until I tried it... 4.2 Supercharged Vogue SE
Post #245869 2nd Mar 2014 8:02pm
Glynn
So no need to press any button in the car 1st ?.
I'll try it though.
Post #245870 2nd Mar 2014 8:04pm
Must have bluetooth ... thought you tried that way first ====================================
Post #245871 2nd Mar 2014 8:11pm
Glynn
Just tried it as you said and the iPhone comes up with a message
"pairing unsuccessful"
Make sure "Handsfree" is turned on,
in range, and is ready to pair.
So it looks like it has bluetooth but won't pair, damm.
Post #245876 2nd Mar 2014 8:25pm
Chauch
Have you got another phone to check it with? Pairing unsuccessful sounds to me as if it found it?
Did it ask for the code?? 4.2 Supercharged Vogue SE
Post #245881 2nd Mar 2014 8:40pm
Glynn
No it didn't get to the ask for code state.
Interestingly it came up with "Handsfree" rather than "Landrover ".
Post #245883 2nd Mar 2014 8:47pm
Chauch
That is the same as mine, so the Bluetooth is there…….
May be worth trying again... 4.2 Supercharged Vogue SE
Post #245886 2nd Mar 2014 8:57pm
