Home > In Car Electronics (L322) > Reversing Camera Removal - Advice Please . . .
TugRR
Morning All . . .
So, this weeks jobs include high level stop lamp replacement.
While I have the spoiler off, I want to remove/inspect the reversing camera which is - at best - intermittent.
I can't see how the thing comes off the spoiler and/or housing though.
The car is a 2006 MY and I've removed a small grub screw from underneath presuming this would allow removal ?
I've read about drilling out rivets, but can't see anything obvious . . . and I'm not a fan of brute force on electronics . . .
I'm sure I'm missing something !
Assistance please !
TVMIA
Thumbs Up Where do you go after one of these . . . ?
Post #245192 27th Feb 2014 11:18am
anything in the wiki Paul?
Post #245195 27th Feb 2014 11:22am
TugRR
. . . I've looked through loads of posts, Stan to no avail.
Others have mentioned drilling rivets, as mentioned, and of easy removal - mine won't budge !
Post #245201 27th Feb 2014 11:50am
JAYBOY
Tug
1. Open the rear tail gate
2. Remove top plastic trim
3. There are 3 screws that need to be removed
4. Shut the tail gate.
5. Pull the spoiler towards you gently
6. The spoiler is now removable.
The camera is on 2 plugs, Dan Duckworth's can supply a new one. There's not a lot you can do with them as they are sealed. I did mine and installed a new camera in the original housing.
Hope this helps.
Jay 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #245204 27th Feb 2014 11:53am
TugRR
^ Thanks Jay for the above.
The spoiler is off the car - the problem I have is getting the camera off the spoiler ?!
Is it a "push" or "interference" fit, for example ?
Post #245232 27th Feb 2014 12:36pm
JAYBOY
Take the screw out and put a small screwdriver in between the end cap and the camera housing. it should pop out.
The cables are tight so be carful. In fact I think I pushed as much cable through first. The unit is then sealed. I just prised mine apart and its not a camera that you would think of. Its just a printed circuit with a lens.
PM me if you want with a number and I will ring you and take you through it if that's easier.
Jay Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #245233 27th Feb 2014 12:44pm
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Just done a how to on this tug Thumbs Up F**K IT you only live once
Post #245268 27th Feb 2014 1:38pm
JAYBOY
It was Stu that told me how to do it Bow down Bow down
There also a how too here
http://www.fullfatrr.com/forum/topic4621.html 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #245271 27th Feb 2014 1:43pm
TugRR
Thanks both, Jay & Stu - camera now removed . . . phew.
There was absolutely no way it was going to come out as it should have.
I ended up effectively splitting the sealed camera unit and removing the complete housing off the spoiler before I could remove the reasr half of the camera.
Off course, it was easy to see how it SHOULD have come off, but it simply wouldn't slide out of the guides.
I had to pretty brutal and now I know where the rivet is . . .
I'm going to hand the camera over to my Dad (he's a bit of a techy anorak) before condemning it - it was, after all, working sporadically.
If there's no joy with that - I'll have a look at your method, Stu -
Thanks again !
Post #245311 27th Feb 2014 3:33pm
