Home > Maintenance & Mods (L322) > Cold start
Beanoraa
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Cold start
Hi every one,my 2005 sc is playing up for a while now when starting on cold mornings she starts to run a bit rough sounds as if not running on all cylinders when she warms up she's fine. Some times I get the engine management failure on dash when this happens she is low on power I switch off and on again and it will run ok again. Just had new spark plugs fitted yesterday but did not fix. Can anyone HELP.
Post #244757 25th Feb 2014 8:20am
mjdronfield
Not got an SC myself, but if the engine management light has been on, there should be a fault logged.
If it was me I'd get the fault read with a diagnostic tool.
Good luck with finding your issue.
I'm sure more SC knowledgeable people will be along shortly......
Could be a coil pack failing...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #244868 25th Feb 2014 6:01pm
Beanoraa
Thanks mjdronfield for the reply somebody else I was talking to said something about the coil I will get that looked at. Going away on holidays for a few weeks so it will have to wait till I get back. Don't know if fault is logged ,when I press the button on dash it says check ok.
Post #244870 25th Feb 2014 6:12pm
mjdronfield
The fault will be logged on the engine managements system. The cluster won't show it to you. You will need to get a garage to plug a diagnostic tool into it and read the faults off.
You may find it more cost effective to buy a diagnostic tool yourself ? Depends whether you may want to do some diagnosis yourself and how long you plan on keeping the car etc. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #244871 25th Feb 2014 6:21pm
Beanoraa
Ok thanks will get my garage to plug a diagnostic tool into it they charge £30 not to bad
Post #244873 25th Feb 2014 6:27pm
mjdronfield
Could be worse.
You will be able to go from there then.
Let us know the outcome.
Others may have more ideas, but that's where I'd start.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #244874 25th Feb 2014 6:31pm
Beanoraa
Will let you know in two weeks time Thumbs Up
Post #244875 25th Feb 2014 6:37pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Did you find a solution as my SC has developed a similar fault.
Starts fine in warm weather, but now winter has come, when I flick the key, it starts then dies within a few seconds.
If I give it some throttle when I start it, I can often keep it going until it picks up. This usually takes a few seconds of rough running and then is fine.
Suggests that it is a fuel problem to me.
Any thoughts?
Regards.
Anthony 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #303268 7th Jan 2015 8:04am
