Home > Technical (L322) > TPMS!!!!! |
RoryM Member Since: 03 Mar 2013 Location: Ireland Posts: 51 |
Main dealer wont turn off my TPMS.... so bloody frustrating! |
24th Feb 2014 3:22pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35161 |
get an iidtool and do it yourself [and other stuff] |
24th Feb 2014 3:31pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2251 |
+1 also I use main dealer as have a landrover warranty but always run the diagnostics before it goes in and when it comes back out to see what they should be doing and what they have done and they are not expensive |
24th Feb 2014 5:36pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Tyre pressure monitoring system not worth the hassle! Rory as said get yourself an iid tool and say good bye to the dealer Present :2008 TDV8 HSE
24th Feb 2014 9:40pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Thanks. I don't think I have that do one less thing to go wrong. There is a difference between knowing your sh!t and knowing you're sh!t
24th Feb 2014 9:48pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I'll second all the above. They're a bloody nuisance and I got an IID specifically to turn it off.
25th Feb 2014 8:13am |
also Rory, because the tpms valves corrode when you get the chance replace the tpms valves with normal rubber ones. |
25th Feb 2014 9:34am |
Thanks guys, I kind of assumed I would get this sort of reply. IID tool it is then.
25th Feb 2014 3:25pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
A wanted post may help, they seem to fetch in the region of £150 then as long as the model you have is in the same bracket as the sellers (ie:2005-2009) it is £25 for a new licence. If the car is in a different era then its £80 to re-licence. Ian |
25th Feb 2014 3:58pm |
