Home > eBay & Bargain Spots > Cheap TDV8 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3079 |
All you need is a HUUUUGE bottle of T-Cut!!
21st Feb 2014 7:04pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
Maybe we could all chip in and have it garaged up somewhere for bits when required! |
22nd Feb 2014 7:50am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
OK here is my $40 , now can I have the engine
22nd Feb 2014 8:08am |
It looks in nice condition everywhere else apart from that corner.
22nd Feb 2014 2:54pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
It is cat d which means it should be repairable, but thats not to say its not going tk take a huge effort, at a few hundred quid its a no brainer, but it would take having it in the air to have a look to see what is bent, obvoiusly the suspension is gone, but that has probably taken the subframe with it, possibly the top mount for the strut whch seems to be too far over, if the screen needs replacing it possibly means the frame is deformed, there is a turbo behind that innner wing, the fbh in there also, that will most likely have gone too, so it all starts adding up, all to be left with a cat d repaired car at the end of the day.
22nd Feb 2014 3:28pm |
TBH i think it would have been valued at even more for the repair and i bet a new shell would have been mentioned once or twice as the easiest option...
24th Feb 2014 1:12pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
More prob go to a ringer tbh _____________________________________________________
25th Feb 2014 12:14pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
SE with no RSE?? |
25th Feb 2014 7:45pm |
73vse Member Since: 27 Dec 2013 Location: North Yorkshire Posts: 97 |
Facelift didn't get rse as standard , |
25th Feb 2014 8:00pm |
