Home > In Car Electronics (L322) > How does the Dension iPod link work |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Pictures might help us , after much research on here it has been discovered that the Denison Gateway doesn't work on the FullFatt and it has to be the LR dedicated kit plus it usually mounts up front .
23rd Feb 2014 1:01am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
If at all it should work via the cd changer input on the screen afaik, the lr kit is basically a special dension kit, but the standard gateway doesnt work with the most architecture of the car. There is nothing that can't be fixed with a hammer😜😜
23rd Feb 2014 8:07am |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 |
Thanks guys, this is a picture of what I have within the glovebox, but no clue how to activate it. It has an Apple connector, a USB and a box for 2 phono plugs with a switch.
23rd Feb 2014 8:11am |
Try sliding the switch on the phono box? Then trying the ipod? There is nothing that can't be fixed with a hammer😜😜
23rd Feb 2014 8:56am |
To be honest, I only spotted that box lurking at the back when I took the photo as the iPod lead was in the front....
23rd Feb 2014 9:16am |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
So has someone retro fitted that at some point? 2006 4.2 SC
23rd Feb 2014 9:18am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Great result. When I enquired the LR version was about £600 and still had limitations with big libraries and needed you to set up playlists which was the main reason I didn't spend the cash There is a difference between knowing your sh!t and knowing you're sh!t
23rd Feb 2014 9:34am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Yes it would have been retro fitted in any FF... i.e. Dealer fit option
23rd Feb 2014 9:39am |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 |
Wish I could find one in my glove box! I enquired of a couple of ICE types as to fitting a new one who replied that it would cost £600+ to fit... |
24th Feb 2014 12:29pm |
Yes, quite pleased with the find now I have got it working 4.2 Supercharged Vogue SE |
24th Feb 2014 10:07pm |
bonus There is nothing that can't be fixed with a hammer😜😜
24th Feb 2014 10:16pm |
John Member Since: 18 Feb 2014 Location: Longfield Posts: 69 |
can you send me the details of this please. i did try to PM you but im a new member and the forum wont let me many thanks john |
26th Feb 2014 12:32pm |
Hi John, mine is located in the glovebox just under the CD Changer. Apparently an official accessory but quite expensive to fit if you do not already have it…. 4.2 Supercharged Vogue SE |
26th Feb 2014 6:05pm |
thankyou i will make inquires about it.
26th Feb 2014 7:52pm |
