Home > Technical (L322) > No HDC and No Change of Transmission Range
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I think that the two are connected to my swapping the panel around the gear selector which meant I had to swop the switch pack from my brunnel grey panel to the painted panel which had no electrics. The switches have positive click give no response when used. All wires are connected as I did double check.
I can get the transmission to engage Low if I hold either switch as I plug in the connector so I think it must be a problem with the switches but would appreciate thoughts/comments.
Car drives fine in High Ratio and everything works except for the HDC and switching to Low Range. [/img] There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244131 21st Feb 2014 7:54pm
rej
Any idea if this is likely to just be a faulty switch or something more complicated. No obvious error codes when scanned on iid. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244220 22nd Feb 2014 12:33pm
Assume it was all working OK before the panel swap?
The two are linked together looking at the wiring diagrams (ZF) so suggest you run back through all the connections again.
A battery reset might sort this out? .
Post #244230 22nd Feb 2014 1:19pm
rej
Sorted
New central control panel and HDC and Low Range working again. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244962 26th Feb 2014 9:55am
