![]() | Home > Technical (L322) > New Windscreen Time |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Not a fitter myself, but work in IT for the parent company of a national windscreen replacement company and have spent some time with the techs out on the road in their Transits.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
I had mine replaced last year.
Mine is in today to have a third screen fitted |
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Had new heated one fitted yesterday by Autoglass - very pleased so far. Went for their "budget" screen as a premuim was needed to be paid for a LR one. The make is " Shatterprufe life time guarantee" Time will tell.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
it will certainly be 'clear' if something is wrong..
Will it not be clear if it's right, or unclear if it's wrong, or perhaps dirty ?
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Can you ask for a genuine LR one? |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 256 ![]() ![]() |
Yes. Competition Act 1998 refers.
Yes - I did
Glassman Member Since: 08 Apr 2014 Location: London Posts: 19 ![]() ![]() |
Not "poss", definitely. The wipers should come off without fail.
Debatable. Most replaced windscreens will come out easier than the factory fitted ones. This is because an alarming number of windscreen fitters are not fitting them well enough. It's also scary to see that very few fitters are not removing contaminants from the substrate (which are introduced during windscreen manufacture). A crucial part of the glass preparation which you did not mention.
Rust inhibitor? Check the label! It's an adhesion promoter which has its uses. Every polyurethane adhesive system will have a slightly different procedure, but the underpinning factor throughout is to minimise the risk of breaching that painted surface. This will be easier to achieve by using an appropriate cut-out wire; a chisel to cut back the old PUR (and not a knife!) and having the right skills goes without saying. Generally speaking, the 'rust inhibitor' you mention is used on freshly painted surfaces, or to cover any bare metal which may have been exposed during the cut-out stage. It is not for painting over scratches; a fitter should not be scratching a car although the process of painting over a scratch would make the 'primer' a rust inhibitor and therefore reinforce the common misconception of its use and purpose.
We?? Everyone uses the same "special" V-shaped nozzle! It is not specific to any one company. Applying the correct bead height, in the right amount, in the right place (using buffers where applicable) will prevent the PUR going where it shouldn't and "squishing" everywhere.
It is the fitter's responsibility to check for damage and imperfections when he takes ownership of the glass as he places it in his van, or on his trestle, pre-installation. Minor imperfections are not always apparent and will sometimes go unnoticed until the driver spots it whilst driving. |
Thanks for putting me right glassman. As I said at the beginning, I work in IT, I am not a windscreen fitter.
^ being an IT chap you certainly know more about windscreens than a windscreen chap knows about IT.. |
Misinformation is rife in any industry. This is why I don't go around telling people to open MS Office by using a tin opener.
Thanks Stan.
