Home > Technical (L322) > IID Tool Errors
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
IID Tool Errors
I have gotten my IID tool working and run a check of faults, cleared all and then run again but I seem to be left with several faults about lost communications, as these normal or do they potentially indicate major problems. I will try and make a note of them all and post in due course. Car seems to be running OK. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244141 21st Feb 2014 10:03pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi Rej
Faults codes with the U prefix and “lost communication with …” descriptor are often present on these vehicles. They should be left alone unless there is a real issue with a system. These faults will register from time to time for no apparent reasons.
Cheers
Post #244143 21st Feb 2014 10:37pm
rej
Thanks, that has put my mind at rest a bit. I will double check when I have time to record all the codes for any that look different.
Is there a list of codes and their meaning anywhere? There is a difference between knowing your sh!t and knowing you're sh!t
Post #244144 21st Feb 2014 10:46pm
PatGAPInnov
Site Sponsor
Hi Rej
My pleasure .
Unfortunately, such a list does not exist. Keep in mind that the descriptor are the same ones you would have by using the official Land Rover diagnostic equipment.
Cheers
Post #244145 21st Feb 2014 10:51pm
there are two links for codes in the wiki..
Post #244146 21st Feb 2014 10:51pm
supershuttle
I have found that inserting the key and pausing for a second before turning on gives me less communication errors.
HTH Geoff
Post #244148 21st Feb 2014 11:21pm
RR2008HSE
I also got lots of these codes and was quite worried. Don't be. The advice above is good. If in doubt, copy down the codes, then ask IID for their advice. I've found them very helpful and very prompt in their replies.
Post #244167 22nd Feb 2014 3:10am
