Home > Technical (L322) > Air leak |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35348 |
theres an air tank where you say its leaking , maybe one of the connections has come off or the tank is leaking?
19th Feb 2014 6:42pm |
daddyg Member Since: 23 May 2013 Location: Broughty Ferry Posts: 11 |
Cheers Stan. I'll give it a go in the morning and report back. |
19th Feb 2014 9:33pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Can be the connector-ventil under your driver door, look in RSW-Solutions on YouTube, there are the pipes to see, and the advices to dismount the shapes. Goes the car down to the floor, when the one hour time is over? L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
20th Feb 2014 7:19am |
Right. Found the leak and like you say Stan it was the air tank. It appears that mud has got trapped between the bracket for the side step and the tank and has corroded it away. Unfortunately I've made it worse whilst I was poking about.
20th Feb 2014 11:25am |
The weird thing meerbusch is that it isn't losing height. Although we'll see now that I've made it worse! |
20th Feb 2014 11:26am |
if your poking about didnt exasperate the problem then drive as you did but get it sorted asap.. |
20th Feb 2014 11:50am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
I would think the compressor will be working full time to keep the reservoir with enough air to keep the system going.
20th Feb 2014 11:55am |
