Home > Maintenance & Mods (L322) > woe is me - coolant leak
markcartlidge
Hi All,
Looking for a bit of guidance. Completed an oil change on saturday which went fine apart from have a load of oil leaking from the filter housing. On refilling and testing the dreaded bong "Check coolant level". Promptly did so only to find the reservoir empty, filled with about 2 ltr of water. Went out to the car last night ( not used ) and needed to put another 2ltrs in. Drove about 35 miles and need to add more water. No signs of contamination either in coolant or oil. Limited signs of water any where in the engine bay other than below the oil cooler. It has had a new radiator about 25k ago.
My question is where do I start as it looks like some dismantling is required to identify where the leak is coming from?
Any advice appreciated.
Thanks
Post #243290 18th Feb 2014 8:29am
pld118
Heres a start but it will likely be something unrelated to the issue I had:
http://www.fullfatrr.com/forum/topic21436.html?highlight=ptfe
And this was another recent post too
http://www.fullfatrr.com/forum/topic22209.html?highlight=coolant
Good luck
Post #243300 18th Feb 2014 9:29am
if your coolant level was ok before then you've dislodged a pipe whilst doing the oil change..
Post #243301 18th Feb 2014 9:37am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
My leak was this after a rad change.. water pump bolt and O ring .
http://www.fullfatrr.com/forum/topic23001.html If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #243308 18th Feb 2014 10:11am
markcartlidge
Sorry replied to whelshdragons orignal post
Thanks for advice. Out of interest welshdragon where did you get the o-rings from?
looks like the undertray is coming off Sad
Post #243323 18th Feb 2014 10:50am
The altenators do like to spring leaks on earlt 4.4's too Thumbs Up
Post #243333 18th Feb 2014 11:12am
markcartlidge
spent the last hour looking but no sign of any leaks Confused
Post #243343 18th Feb 2014 11:46am
with the engine running?
Post #243347 18th Feb 2014 12:00pm
markcartlidge
yep and after switched off for a while also.
Post #243358 18th Feb 2014 12:27pm
strange that you have to add so much coolant after a relatively short drive..sometimes using kitchen towel tissue can find minute sprays..
Post #243359 18th Feb 2014 12:30pm
markcartlidge
I think this is a hangover from my oil change. Left of image is front of car looking from under near side wheel arch. It appears to be loosing about 1ltr every 20 miles.
Post #243391 18th Feb 2014 4:39pm
markcartlidge
Found it - back of the engine above the bell housing. Looks like the engine to changover valve hose/coupling.
Any idea of which part I need?
view from top
view from side
Post #243398 18th Feb 2014 5:21pm
steptoe
Part number JHC000081.
Cost me £7.31 last october. Mr. Green
Post #243409 18th Feb 2014 6:42pm
Welshdragon
Glad you found the leak Thumbs Up as for where I got the O ring...my Mrs works at a car dealer so she brought a box of various O rings home Mr. Green If it dont work.......burn it!
Post #243414 18th Feb 2014 7:03pm
markcartlidge
Thanks Steptoe, Looks like the right part.
Post #243424 18th Feb 2014 7:35pm
