![]() | Home > In Car Electronics (L322) > Solar Trickle Charge |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I hope they've improved. The early ones didn't produce much of a charge. Is it worth investigating a kill switch to isolate the battery during long down times? |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
I have two in mine, from Maplins, they both sit either side in the rear window via the suckers provided, i then bought a two into one connecter with a cigeratte light plug into the cubby box, this gives a good trickle charge when not used for a while.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
This is what I used if I was not using the car for a while.....
Crikey, what's the output on that one then CB ? Hardly a "Trickle" surely ? |
this thread now has the risk of becoming mine is bigger than yours |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
contraband
Cheers buddy |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I do like that one from map links but I've got heavily tinted rear windows will it be effective enough with the tints? |
The new ones just need light, not necessarily sunlight.... My fatty had drug dealer window tints and it still gave 18v.. Previously..
Cheers dude I'm off to maplin tomorrow |
Apparently you can link up to 10 of them together mm hybrid anybody |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1750 ![]() ![]() ![]() |
Do you have to unplug them before you start the car. Maybe not an issue but you'd have to open the boot and do that before you drove away..? Ash
I always unplugged mine before I started the fattie... But I only used it if the car was not in use, so it was not an issue. Previously..
