Home > Technical (L322) > Ignition
Rockportpurple
2002 Range Rover Vogue 4.4 V8 Giverny Green
Ignition
Hi guys in need of some urgent help,,
I was stuck in tesco 2weeks ago with the range rover the key wouldnt turn in the ignition,,
Rang AA guy turned up remove ignition barrel cut it open car still wouldnt turn over or start managed to get the car into neutral and recovered me home,,
Now ordered new barrel and black box behind it,
Fitted barrel into the black holder plugged it all into the car all the electric plugs etc,,
Key will not turn at all!! Brand new parts from landrover at serious cost
Totaly lost what to try next???
The battery is full charged the steering lock disengages,,
If i connect the old rear ignition the one with the big white plug in then turn it with a screwdriver the ignition lights come on and last click car wont turn over
Just what is stopping the car from starting even with the immobilizer ring on it?
The new part wont turn the key at all should it be able to without being plugged in?
Im at a total loss now anyone got a match??
Any help much appreciated
Post #242435 13th Feb 2014 11:14am
will this help?
http://www.fullfatrr.com/wiki/Key_stuck_in_ignition
Post #242436 13th Feb 2014 11:16am
also there might be a solution here ,
http://www.fullfatrr.com/forum/search.php?...rch_time=0
Post #242439 13th Feb 2014 11:18am
Rockportpurple
Hi stan yeh ive been through all those and im at the stage where i have the brand new ignition part and barrel so on the table with the key in and still wont turn??
Does it have to be connected up too let the key turn
I have had it all connected up and it doesnt turn at all and ite full ignition barrel and the black module is all brand new still carnt turn the key,,
The barrel is a separate part which slotted in,,have i installed it incorrectly?
Can you install it incorrectly
Just so many questions i need answering to get the car started
Regards
Post #242440 13th Feb 2014 11:23am
T24RES
Has the barrel been built for your key ?
Or is it a generic one? Ian
Post #242441 13th Feb 2014 11:29am
Rockportpurple
The barrel has been ordered from bmw Germany from the chassis number of my car the black part with the locking solenoid on has been ordered from land rover,
When the barrel was seperate i could turn the key no problems,and the black part i could turn from
Position 0,II,III,,start no issues as soon as i put it together it wont turn at all,does this have to be electrically powered too turn now the two parts are together?
And how do you remove the barrel from the black plastic part as i dont want too destroy the new parts?
Post #242459 13th Feb 2014 12:46pm
T24RES
I've not had one to pieces, sounds like something's not HP when they went together. Perhaps CTC might have more experience ? Ian
Post #242473 13th Feb 2014 1:22pm
Rockportpurple
Whos ctc?
Post #242475 13th Feb 2014 1:27pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Hi
If my Range has a flatish Battery my ign key wont turn ,so i assume that your Barrell has to be powered up for it to turn.
Hope that helps.
Cheers Piers
Post #242477 13th Feb 2014 1:38pm
forum sponsor cam-tec-Craig is ctc.
Post #242479 13th Feb 2014 2:03pm
Rockportpurple
Has anyone got his email or contact address please?
I have tried the battery again and its showing 12.7 volts
But even if you plug all the new parts together it still wont let you turn the key
Its as though no signal is going to the solenoid to let you turn the key,
If you use the rear of the old ignition and the new barrel and black part together with the immobilizer ring around it i can get all ignition lights on steering wheel releases
Turn key too final position car wont start at all,,
Seriously pain in the arse now stan been at this 3weeks now and still no further
Post #242488 13th Feb 2014 2:24pm
i dont know enough about this to help much sorry ,
Craigs site is here,
http://cam-tech-landrover.co.uk/
you can also pm via the forum..
Post #242515 13th Feb 2014 4:38pm
