Home > Maintenance & Mods (L322) > non return valve rear wiper.
Googsy
Replaced wiper motor and arm all well but water cascades down rear window rather than jet. So im thinking replacing the nrv will sort. I imagine that it can be from any car once it fits pipe etc? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #242313 12th Feb 2014 9:00pm
This will fit. Thumbs Up
http://www.ebay.co.uk/itm/Screenwasher-Non...1309227783
Post #242332 12th Feb 2014 10:14pm
The NRV only stops water draining back down the pipes to the tank. If the water is cascading down the window then there is plenty getting through. It sounds like the jet nozzle might be missing or something is not connected to it correctly. Previously..
Post #242336 12th Feb 2014 10:29pm
mjdronfield
+1 for contraband.
Nrv will not help you. Only stops the water running back to the washer bottle under the bonnet.
Check the new arm is fitted correctly, as that should have the jets in it, I think......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #242338 12th Feb 2014 10:36pm
Googsy
Jets look fine and are brand new as is arm .will check it out thanks chaps Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #242339 12th Feb 2014 10:39pm
