Home > In Car Electronics (L322) > Voice Commands - no sound |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35154 |
turn the volume up? |
10th Feb 2014 9:47pm |
jeffridj Member Since: 27 Nov 2013 Location: Wales Posts: 29 |
would you like to explain how?
11th Feb 2014 12:00am |
this is in the owners manual and i assume it controls the voice recognition volume, failing this try a battery disconnection..
11th Feb 2014 9:19am |
Thanks but no joy.
11th Feb 2014 2:24pm |
on my touch screen i'm sure theres an option for adjusting volumes of particular outputs like radio,sat nav etc, does yours have a info screen with this option.. |
11th Feb 2014 2:51pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
On the touch screen, press and hold the music symbol (bottom left) and they pop up. Ian |
11th Feb 2014 3:16pm |
Jeff has a non touch screen Ian.. |
11th Feb 2014 3:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7724 |
Are you using the BMW ulf then ? For voice, or the original land rover unit' the tcm and seperate voice module ? 2011 Range Rover Vogue SE 4.4 TDV8
11th Feb 2014 6:24pm |
It's a non touch screen with the original telephone system, not bluetooth.
11th Feb 2014 9:47pm |
Had a fine day today and solved the problem!!
15th Feb 2014 7:20pm |
Excellent.
15th Feb 2014 8:50pm |
MJ - yes I have RAVE, but I've found that the wiring diagrams are great once you understand them, but I've found that a lot of the entertainment equipment connectors are not listed in the connector section. For instance, the Voice Module has connector C2136 the output of the Voice Module goes to connector C2066 then on to C2045 then on to C0981 then C0395 and finally on to the Radio input on connector C0983 and C0098. I can only find C2066 and C2045 listed. Am I missing something? |
15th Feb 2014 9:47pm |
I don't think so. I remember trying to follow a feed once and not all the photos of the connectors are listed.
15th Feb 2014 10:02pm |
