Home > Technical (L322) > Standard hight settings
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
I'm after some infomation please guys.
I am after what are the standard ride settings for my RR, I know you can set them to what ever hight with the idd tool, but I seem to have a the rear off side lower than the near side by 20 mm.
Does anyone have the correct manufacture ride hight settings for access, standard and off road hight.
I want to keep an eye on this one just incase I need to replace that side air bag.
Thanks Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #241669 10th Feb 2014 3:10pm
493mm front and 483mm plus /minus 3/5mm
measured from wheel arch to centre of wheel..
joe90 has drawn up a chart, probably in his gallery.
Post #241680 10th Feb 2014 3:52pm
joe90 [tim] chart
Post #241682 10th Feb 2014 3:58pm
Welshdragon
Thank you Stan
Thumbs Up Thumbs Up Bow down Bow down If it dont work.......burn it!
Post #241695 10th Feb 2014 4:17pm
Welshdragon
After the garage had done a reset on the air sus inactive on Monday, they recalibrated all the corners to 740mm, just wondering if and why are the settings in the above picture are 20mm lower at the rear ( except access hight 10mm)
Not had the fault back so FF must of had a glitch as all corners where slightly differently set. If it dont work.......burn it!
Post #269140 4th Jul 2014 7:00pm
all the front height settings are only 10 mm higher except for the 20mm off road which i presume for more clearance to benefit the front ...
nobody knows why the front is higher, maybe its to give the FF its stance and road holding... ... - .- -.
Post #269158 4th Jul 2014 8:29pm
Welshdragon
well I spoke to soon, message back, roll on Monday when post arrives, then I'll sort it myself and find out why all of a sudden Im getting 'air sus inactive' with no bong and light locked on standard height Big Cry If it dont work.......burn it!
Post #269162 4th Jul 2014 8:43pm
mjdronfield
The front could be different as the wheel arches on the body may not be the same height, in fact, I'll say they are not. When the car sits level, the rear arch is nearer the floor - you are not measuring from the same datum. If you took the reading by measuring from the bottom of the front rim to the top of the bonnet, it would be an even greater reading than the rear measurement, but the car would still sit correctly in the same place, if you see what I mean ?
Good luck with your suspension issue. Much easier diagnosis with the iid. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #269189 5th Jul 2014 6:22am
Welshdragon
Hoping todays post but more than likely Mondays posty will bring new toy Thumbs Up Soon get this FF shaped up the way I want it and diagnosis the fault.
Not even going to play until iid tool arrives, no point imo, as the eas has so may probable reasons. If it dont work.......burn it!
Post #269194 5th Jul 2014 7:32am
Welshdragon
Tool arrived, faults cleared found 2 others, posted else where though, and found steering ball joint foobard !
Just cant find where to knock of that bonging when key in ignition, so annoying this bong! If it dont work.......burn it!
Post #269226 5th Jul 2014 10:37am
Post #269230 5th Jul 2014 10:49am
Welshdragon
Now I thought I saw it posted on here, I looked in the LCM light section but wasn't there....hmmm go and looky again Whistle
Thank you Stan sir Thumbs Up Bow down Bow down Bow down
' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' ' I will pay more attention to forum posts from now on' Laughing Laughing If it dont work.......burn it!
Post #269233 5th Jul 2014 10:55am
Laughing Laughing
have a look on the gap site, put your model and year in and the menu shows what you can do,
http://www.gap-diagnostic.com/products/iidtool.html ... - .- -.
Post #269235 5th Jul 2014 10:59am
Welshdragon
sorted, found it Embarassed Mr. Green and done the fmh reverse lights too Thumbs Up If it dont work.......burn it!
Post #269242 5th Jul 2014 11:52am
