![]() | Home > Wheels & Tyres > alloy welds,anyone had them done..??? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
If they crack once, they are going to do it again.
Welding a cracked alloy? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
dont do it Steve its not worth the risk.. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Ok, there is welding and there is welding......... We use "pristine wheels" to (processionally) referb wheels. They offer structural welding and X-ray as a repair service, i would use one of their repaired wheels, but would certainly not use 3/4 of the crap i see repaired on eBay!!!
To be honest I don't think a reputable wheel repairer would touch one with a crack. I have had a couple of motorcycle wheels repaired (this is a long time ago), but they weren't welded, and the repairer said he could only fix very light damage - otherwise they're scrap. Fortunately mine had very light damage.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
Repaired alloy wheel = overpriced scrap metal
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
cheers guys... |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Had a 19" wheel welded up on a vxr Astra, the weld leaked air
Jimbosgolf Member Since: 11 Feb 2014 Location: Edinburgh Posts: 3 ![]() ![]() ![]() |
I have had alloys repaired before, admittedly they were for a BMW.. It was a waste of time, ultimately the crack will return and potentially damage the tyre.. Meaning you get hit been more (cost of repair,cost of new tyre, and inevitably the cost of new alloy).. I spoke with a chap at local tyre dealership and he confined repairing alloys is only a matter of time before it fails again... I should add that this is in pothole capital of the world (Edinburgh) so the alloys tend to take a hammering |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Not read the above, but there is absolutely no way I would put welded alloys on any of my vehicles - never. They spin at several thousand rpm and disintegration at 80/90/100 on the motorway just does not bare thinking about.
Craig's on the money as usual. IF you can find someone who will do the job professionally, including X-Raying the weld to ensure it's sound then happy days, but that normally costs more than replacing the alloy with a good S/H unit.
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
I would strongly advise against this, I spent a considerable part of my career doing failure investigations and inspections of alloy aircraft wheels. If you weld a forged alloy wheel you can make it so that it will be solid and not leak, there are many skilled welders out there but you will not have the original grain flow and structure and the wheel will retain a weakness in the same spot (likely the most highly stressed area) that it cracked the first time. X-Ray and ultrasound will confirm that the wheel has no cracks or porosity only. |
