you don't have to have a L/R one!! if you go on ebay and see one for a VW it will do the same thing and they are more common!! that is if you are not bothered by the badge on it.
http://www.ebay.co.uk/sch/i.html?_odkw=web...p;_sacat=0
hope this helps, plenty listed here. The older style T90 fob although it is a bit bigger and has less range than the T91, allows you to switch between hot and cold air also. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
