Home > In Car Electronics (L322) > Really impressed
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Really impressed
Just thought I'd post a quick note to say ..
WOW..!
Just got my BM54 and DSP back from Baris..... What a great fella and What a massive difference it makes.
Firstly Baris - I've been out for about half an hour with no drop outs in the sound so it looks like the dry joints were the issue. So pleased so far with the fix..
I opted for the "stage 2" upgrade which gives better output from the BM54 - What a difference it makes to the sound quality both at low level and the ability to crank it up is also greatly enhanced.
I can't thank you enough Baris.... Thumbs Up Bow down Ash
2016 SDV8 AB
Post #241025 8th Feb 2014 1:35pm
it would be nice if baris was a site sponsor then we could give him this business officially..
Post #241027 8th Feb 2014 1:54pm
mjdronfield
To be fair Stan, I did feel a bit bad after all the posts, though it's not Baris who's advertising, its us....
Yes, I'm sure there is plenty of work we can put his way. I think he is a sponsor on a BMW forum.
Well happy with my stage 2 upgrade. Makes it what it should have been. Can't believe how nice the stock system sounds now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #241066 8th Feb 2014 5:35pm
comports
Hey MJ - Did you upgrade your speakers as well..?
The sound is so much better but could do with some slightly better speakers I think. I also suffer a bit of "Bass Rattle". probably because the panels are all a bit loose now.. Ash
2016 SDV8 AB
Post #241076 8th Feb 2014 6:18pm
mjdronfield
My speakers are stock. I did look out for some from the 2005 onwards cars, with the touch screen nav, as I think they will handle more power.
Couldn't see a set for sale on the bay of e, and buying new ones cost a fortune.
Having got the stage 2 now, I'm not sure they would be much better. That said, I'd like to have a good listen to a system with the later speakers.
Baris has ripped his stock speakers out of an M3 he's got, and thinks they can be improved upon.
I want mine to look stock though, so if you know of any that are a direct replacement, let me know.
I also understand the stock speakers are a non standard ohm.....
When you look at the cones on the stock speakers, they don't look brilliant, but sound pretty good for a stock system. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #241078 8th Feb 2014 6:47pm
Put the later HK speakers in Thumbs Up Did it in my previous 04 and it made a massive difference Thumbs Up
Post #241295 9th Feb 2014 11:24am
mjdronfield
I looked at doing this before, but couldn't find any for sale.
New ones cost a fortune, and I dare say you'd need to change all 12 (?) to make it sound right.
Where did you get yours from ?
Do you know of any anywhere ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #241333 9th Feb 2014 1:10pm
dan_uk_1984
What was the final price for this job? I have a faulty BM54 I could get repaired & upgraded and not have to be without a radio...
Post #241341 9th Feb 2014 1:46pm
mjdronfield
You'd be best to pm Baris, but if it's a channel down in the amp, it gets fixed by the amp upgrade. I paid £79.99 as I had already had the stage 1 upgrade 2 years ago.
I've got £149 in my head for a straight stage 2, but you'd need to check.
If the upgrade would not fix the fault on the unit, he does a repair service if you just want that. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #241343 9th Feb 2014 1:54pm
comports
It was indeed £149 for the full stage 2. Great service as well. Sent the unit off and it was all done (repaired dry joints in my case), upgraded and back in my car within a week.
I guess it depends on how bust Baris is but PM him.. Ash
2016 SDV8 AB
Post #241345 9th Feb 2014 2:10pm
