Home > Maintenance & Mods (L322) > Definitive Battery Guide for 2010 model |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I'm surprised it does not fit mine has the same engine as yours and I too have the safety device fitted and the bosch fits mine . Present :2008 TDV8 HSE
8th Feb 2014 11:52pm |
It fits with a bit of fettling. My previous TDV8 had the big Bosch and it also had the pyrotechnic charge safety thing. A bit tight I agree but it definitely fits. |
9th Feb 2014 7:35am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
You will see that others, like me, had to saw off the flange at the bottom of the battery to get it to fit. It is strange how some people get them to fit in the same model year, with the pyrotechnic attachment and others have to do the mod. 2012 5.0L S/C
9th Feb 2014 8:00am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8507 |
I am gong to be swearing at this today too, so will put up some pics.
9th Feb 2014 8:17am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
Yep, I have a 2007 TDV8 with said pyrotechnic charge and the big Bosch battery fitted fine with no modifications at all, it's tight sure, but patience as well strength and some jiggling with the bonnet in access mode was all that was required in my case
9th Feb 2014 8:20am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
wish id taken some pics now.i calculated that it *may* fit if the wing-end foot of the battery was cut off but even that would result in the wing end of the battery sitting on the battery tray vertical ridge so if you're happy with that then maybe it does.
9th Feb 2014 10:36am |
Ok,
9th Feb 2014 10:54am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
Dexion7 - is yours a TDV8 ?
9th Feb 2014 11:43am |
does that not squash the pyrotechnic device and its very heavy +12v cable against the vertical bulkhead? |
mine is a tdv8
9th Feb 2014 11:51am |
Less than 1mm
9th Feb 2014 11:59am |
so is the battery negative end sitting on the vertical flange of the tray thus making the battery sit wonky? |
9th Feb 2014 12:07pm |
Once the battery was in place, I used a crowbar to move it to the outside so that I could get the pyrotechnic charge in - it's very tight, but does just fit |
9th Feb 2014 12:08pm |
No, sitting flat in the bottom of the tray.
9th Feb 2014 1:56pm |
