Home > General > 1st Lesson learnt! ! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
We've all done it
8th Feb 2014 8:33pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Yep and mind that alternator they are very prone to failing on 2007 and early 2008 cars. I would charge battery with a charger rather than loading the alternator. Present :2008 TDV8 HSE
8th Feb 2014 9:02pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Gadgets never mind them watch those puddle and tailgate lights too! Flattened my battery on the D1 while fitting electric seats in it a few years ago If it dont work.......burn it!
8th Feb 2014 9:18pm |
ij.brooks Member Since: 12 Oct 2013 Location: Newcastle upon Tyne Posts: 30 |
According to the service documents that came with the car, the battery and alternator was changed in December 2012, so would be unlucky if it was bust again. At least I am not the first to accidental flatten a battery, sure I won't be the last. |
8th Feb 2014 10:31pm |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
Welcome to the club I did the very same when I got mine showing every one all the toys Came out next day with the wife all ready to go out none start battery flat. Had to put it on charge red faces all round . Now when working on car I plug batt charger on & have changed all puddle & interior lamps to led bulbs. |
9th Feb 2014 3:17am |
A warranty won't stop the battery going flat and a warranty won't replace the batter for you either. My experience with insurance backed warranties is that they are simply not designed with the RR in mind. I had a fully comprehensive warranty on mine from warranty direct, even though it was meant to be comprehensive they changed the terms every 5 minutes. If something was on their list of things then you had to wait for an assessor to come out (5 working days) and they had to agree with your garage that x part is indeed faulty. They would then make you wait further whilst they thought about your claim. Basically it's as complicated as insurance when you have an accident. Just as long winded and time consuming. I never once actually managed to get them to pay for repairs. They either rejected the claim in the case of the steering column, hand brake, water pump and wiper motor. Or just made it so long wonded I would have been without transport for 2/3 weeks. My advice is to put that money in the bank! |
9th Feb 2014 8:44am |
I know they wouldn't cover me against the battery, my daft fault, but it did make me realise how easily things can go wrong. I was considering warranty direct, after reading some positive review on here, also read some bad review!, but now all confused again. |
9th Feb 2014 8:52am |
How much have you been quoted for the warranty? |
9th Feb 2014 9:09am |
They quoted £835 for a year, with a £50 per hour labour rate. if I decide, I'm hoping to get them down abit. |
9th Feb 2014 9:41am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
I guess it depends how many miles the vehicle has done as to what the warranty costs?
9th Feb 2014 9:56am |
Managed to flatten mine once in the channel tunnel - good job I was fairly near the front for the indignity of getting pushed off
9th Feb 2014 11:16am |
I've NEVER spent that a year on failures, even including maintenance and upgrades etc and I've had 4 FFRR's now. Also at £50 per hour labour cap that rules out main dealers (£150ph) and higher end garages that supposedly know what they're doing. |
9th Feb 2014 1:52pm |
Really, I was thinking about putting a few grand in the bank or warranty. But the horror stories of turbos, gear box or suspension scares me, my car is 7 years old and 79500 miles on. Doing about 12000 miles a year. I have emailed a couple of independent land rover specialist around my area about there labour rates just to help with decisions. |
9th Feb 2014 3:15pm |
Has your gearbox been serviced at all? If not an oil change is great preventative maintenance.
9th Feb 2014 3:59pm |
