![]() | Home > LPG > BRC lpg |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
from what I have seen on this forum, it's not so much the manufacturer that you need to make the decision about and more about the installer and their experience of fitting kits to Fatties |
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 141 ![]() ![]() |
I think that's a fair point. Are we talking about more than neat and tidy installs? Presumably the basics have to be correct or it won't work? Pipes could be rerouted to tidy up if necessary. |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi David,
Good to know Andy, thanks. My old LSE is going to need work (although the lpg has always been fine).
Agree David, Petrol and Gas is the way to go. The LSE is such a classic beast, good ones will only appreciate in value as time passes.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
prins and brc are the better makes, but these are only good if it is set up properly. once setup the install data can be copied for a similar car. so, if using an installer that hasn't had aFFRR in, this will take a few visits to fine tune the setup etc.
my system is a Prins and it is flawless; but then it has been professionally installed. there are real cowboys out there. people I use are http://www.autotech-lpg.co.uk/ |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Tartarini manufacture an excellent system http://tagas.co.uk/index.html |
Thanks all. I'll see how it all pans out. |
David, I have a stag system installed 4 yrs ago by autoprofessgas just north of Newport. Never had any problems and they give excellent customer service. A few other forum members have used them too to good reports. |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
i am with Soggy on this one, prins all the way and autotech ![]() this is the best working thing on the rangy, and best money i ever spent. |
I have a decent lpg place in Blaze who see my current car now and seem well thought of. I doubt its worth buying a car and converting it, cost wise so I'll keep an eye out.
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
I've had a BRC system from Captipal Autogas on mine for the last 75K.......xclent.
