Home > eBay & Bargain Spots > have you got one of these? could be useful |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
I have ordered a dash camera, and also a dummy fuse, so I can run it from an ign supplied 12v so I never have to remember to switch it on or off. ie wire it from a 12v dc plug hidden away. BUT should I want to override it and switch it off for some reason, I needed a switch that's convenient. and I remembered I had seen this item before. So, I ordered one
6th Feb 2014 9:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
you do know that dashcams have on/off switches ?.. |
6th Feb 2014 10:04am |
i see, another solution could be if the dashcam has an auto off, most do, then pull the power plug out .. |
6th Feb 2014 10:59am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3182 |
I have one of these already fitted as power for my RSE. You will have to replace the whole panel to fit or cut it on?
6th Feb 2014 11:16am |
mine is in. but i cant show you a picture yet, but yes, it just pops straight out and in. just use a mans thumb nail to get round the edge, and pull.... its clips are on the sides (4) so pulling from the front or rear will relieve it. this is for manual winding of the sunroof i believe with that cranked allen key we all wonder abount in the tiny tool roll. i think its purpose intially is for driver control of the overhead dvd player option??? |
6th Feb 2014 3:10pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Useful switch panel if you need to fit accessories. |
6th Feb 2014 3:20pm |
