Home > Maintenance & Mods (L322) > Cleaning your inlet manifold with Mr. Muscle?
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Disconnect the EGR pipe where it connects to the exhaust manifold, not the egr end.
To locate it look below the air intake pipe to the air filter housing, you'll see a small metal pipe about an inch in diameter secured by two bolts to the inlet manifold, using a plastic pipe you inject the cleaner direct into the turbo housing through the egr pipe hole.
Post #240206 5th Feb 2014 11:20pm
