![]() | Home > Technical (L322) > warning |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Maybe either? 1st check the electricals... Battery charged? Any good? |
Bozzy1954 Member Since: 04 Jan 2012 Location: Derbyshire Posts: 27 ![]() ![]() ![]() |
Hi thanks for the reply, I have had to have the car jump started due to it not being used for a few mnths, just had a new frontend and rearend after a snow plough pushed it of the road. I just took it for a run 30mls is that enough to fully charge the batt.? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
did you set the steering parameters? |
I only fitted the panels,a garage did all the fiddly bits, the front was only cosmetic just upgraded to the face lift front. |
when the battery is replaced or goes flat ,you have to turn the steering wheel fully left then fully right..try disconnecting the battery and follow this procedure, details are in the wiki......... |
Ok I'll give that a try. |
Panic over just a sensor playing up, reset its self now. Thanks for your imput, |
If your battery has been flat for a while keep an eye on it. You only get 2/3 deep discharges out of a battery before the plates are knackered and it will never hold a full charge again. |
Thanks for the info, because I'm away a lot the car does not get used a great deal. |
