![]() | Home > In Car Electronics (L322) > Radio problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
battery? |
More than likely your bluetooth module my friend... Water ingress? Check for wet in it, then check top left boot seal and see if its expanded and rippled on the corner |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
Mine went similar to this just before we discovered our battery wasn't up to scratch so replaced the battery. New battery = problem solved so perhaps yours is the same? 2011 4.4 TDV8 Autobiography |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Check this -same issue. Check spare wheel well for water and the left hand side boot seal. Built badly but look good;
So dry out the rear, check all connections for corrosion etc., try battery charge and battery disconnection procedure.... .
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Water via tailgate seal, fixed, cured |
