Home > Technical (L322) > Rear Disc's and Brake Shoe Q??
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Ive got to do my rear discs and pads, now im guessing the car is still on its stock rear shoes as well whilst im doing the disc's should i do the shoes out of course??
The car is on 70 thousand the hand brake works fine but in my head if im doing the discs i might as well do the shoes?
Also do i need the brake shoe spring kit ive seen knocking around to replace springs etc?
thanks
Neil
Post #238791 1st Feb 2014 6:53pm
T24RES
I'd be inclined to check the handbrake shoes. A rub with some emery paper or similar will be all you need in most cases.
Post #238799 1st Feb 2014 7:28pm
Neil, don't forget to back the handbrake shoes off before trying to pull off the rear discs sir... Last thing you need to do is pull the pins through the back plates Whistle
Post #238841 1st Feb 2014 10:42pm
cliffy
cheers guys, Craig yeah done that years ago on a ML oops Embarassed
Post #239018 2nd Feb 2014 6:36pm
Googsy
I read that if you release epb with engine on then turn off car the discs can be removed without need to wind back handbrake shoes? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #239048 2nd Feb 2014 7:53pm
Depends if they clear any lip on the inside of the drum Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #239324 3rd Feb 2014 6:05pm
