Home > Technical (L322) > Aux Heater Pump - Where to buy?
ChrisHamblin
France 2004 Range Rover Vogue Td6 Stornoway Grey
Hi All,
I've been a guest viewer of the forum for a while but now I'm in need of some help so I'm hoping someone can be of assistance... I need to identify a faulty component on my L322 TD6 (2004). It is mounted to the chassis using a rubber mount - it's on the offside rear, underneath the car, above the drive shaft.
It looks like a valve of some kind - it has a power or sensor line connected to it and appears to have at least and in and out hose connected - on a quick initial inspection I couldn't say for sure if there were 2 lines or 3. The immediate connections are rubber hoses but it looks like these connect to metal piping after a short run. It did have some kind of metal ball in it - suggesting a ball vale of some kind - but the plastic has sheared and this has fallen out. I've tried to take a pic but it is rather hidden!
I am guessing it is either related to the fuel system or the air suspension?
Any help would be much appreciated, looks simple enough to swap once I know what it is!
Thanks,
Chris
Post #238471 31st Jan 2014 12:37pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
fuel pump for the fuel burning heater by the looks of it
Post #238517 31st Jan 2014 3:34pm
ChrisHamblin
Just pulled it off - you're right, small pump for the pre/aux heater. It's labeled as part:
Thomas Magnete 89372A
Google doesn't list many for sale... any tips on who might have one they can ship to France? Rather avoid ordering through a French dealer, that could be quite eye watering!
Cheers,
Chris
Post #238558 31st Jan 2014 5:30pm
ironhorse
they made made by webasto a lot of vehicles have these heaters (top end rovers you can find in scrap yards) for a cheep second hand one
look on the MG forum for a bloke called French Mike might be able to point you in right direction
he IS the guru on FBH and lives in France
Post #238563 31st Jan 2014 5:44pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
There's loads on eBay!
Not sure if Duckworths would send to Europe. Send Dan a message.
Post #238566 31st Jan 2014 5:47pm
ChrisHamblin
Just bought one from eBay in France from a German supplier... fingers crossed, should be ok!
Question is, can I drive the car without it if needed? It doesn't seem to be leaking with it removed... but I guess that could change once running.
Thanks for the help so far! I had initially feared it was a leaky diff so it's quite pleasing to find the cause of the leak to be much more straightforward - phew!
Post #238575 31st Jan 2014 6:14pm
ironhorse
just plug the rubber pipes with a 6mm bolt to keep the muck out and stop it leaking,might be best to pull fuse 59 to stop the FBH firing up and locking out
Post #238589 31st Jan 2014 7:06pm
PaulB
Post #238592 31st Jan 2014 7:43pm
