Home > Technical (L322) > Steering Problem
Nod 1
United Kingdom 2010 Range Rover Autobiography Black 5.0 SC V8 Santorini Black
Steering Problem
Hi to one and all
I hope one of you guys has an answer, because main dealers are stumped. There are times when I turn the steering wheel that I get a strange rumbling feeling through my hands. Its as though some cogs somewhere are not meshing properly. It does not affect the steering at all, yet it is a strange feeleing. Also does this on full lock either way. The rack has been replaced and also the regulator that attaches to the rack.
I wondered if it was something to do with the powere steering system?
ANy thought would be grately appreciated, vehicle is an L322 2004 model
Cheers to a great site
Nigel
Post #23820 31st Jul 2010 12:09pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Re: Steering Problem
Nod 1 wrote:
... because main dealers are stumped.
Thats not a hard thing to acheive Whistle (Guessing by your location you use same local dealer as myself - Stratstones?)
Does this problem occur whilst driving at any speed or just when the car has been started / during parking manoeuvres?
As far as I am aware the power steering pump is belt driven and rack is hydraulic (no cogs as such Neutral )
All Range Rovers (P38/L322) I have owned have this slight resistance/knocking sensation when the steering is on its fullest lock (left or right) which I assume is just the regulator reaching its limit of capability...
(someone more technically minded may be able to phrase what I have just in a better way)
I only (very occasionally) notice mine doing it when pulling out from my driveway onto main road (Very tight turning)
Post #23822 31st Jul 2010 12:19pm
daveo
how about the abs, i have had something similiar when i done the brakes at the front,when i replaced the wheels for the first 2/3 meters that made a rumberling through the steering, just a thought.
p.s do you have 22's on te car V8 facelift Range Rover Autobiography 22" wheels.
Post #23828 31st Jul 2010 12:58pm
dantheman
Yeah, sounds like it could be a bit of cavitation from the pump as the steering rack reaches the ends and an increase in resistance. Have experienced this in other vehicles, and has not been something worth worrying about if that's the case.
Post #23829 31st Jul 2010 12:59pm
daveo
i to get a small sudder when on full lock but was told its down to the 22's and have read that is the norm.. V8 facelift Range Rover Autobiography 22" wheels.
Post #23831 31st Jul 2010 1:03pm
Nod 1
Your right about Stratstones. Not had very good experiences with them especially my last RR P38. In the end went to Lancasters got far better service.
Thanks for the input. Yes I have got 22" wheels and also I have only noticed it since I had front tyres changed.
It is more like a rumbling. Is it posible that the elt might be slipping on P/S. It's just weird, as I said it doesn't affect the steering and it only happens on idle and at full lock.
One other niggle at the moment. Incar phone has stopped recognising sim card. Any ideas ?
Cheers again
Nigel
Post #23839 31st Jul 2010 3:53pm
daveo
hi, if it only does it on full lock i would say thats nothing to worry about, my car and my mates bothe do it on full lock. V8 facelift Range Rover Autobiography 22" wheels.
Post #23844 31st Jul 2010 5:02pm
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Mine does it on full lock but only when in access/parking height. I'm also running 22's
Post #23863 1st Aug 2010 7:25am
PJS
Is that a problem/annoyance for you guys?
Post #23893 1st Aug 2010 2:14pm
Jay
United Kingdom 2003 Range Rover Vogue Td6 Stornoway Grey
dantheman is right in his thread, it sounds like cavitation of the steering fluid, alot of vehicles do this, there is a 'bleed procedure' but in many cases it will self bleed. It is certainly nothing to get too worried about. Big Cry
A reminder -
Fluid level check when cold not hot.
turn strg lock to lock several times to bleed.
Steering fluid is the same as AT Fluid (TQF). Thumbs Up 2003 TD6 Vogue
Post #25108 9th Aug 2010 1:30pm
the FFRR is a four wheel drive , so at very slow speed and on full lock , the wheels are 'fighting' against each other so you get a juddering and a resistance on the steering wheel...nothing to worry about.. ... - .- -.
Post #25112 9th Aug 2010 1:51pm
Discocuzzy
Does this judder happen at standstill when in drive and disapears when you knock it into park or neutral?
Post #25122 9th Aug 2010 4:03pm
