![]() | Home > Maintenance & Mods (L322) > Advanced Factors do Brembo pads,discs & brake kits |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
EBC pads are brilliant, never been able to knock them. the Green stuff pads very popular amongst Defender owners.
Good tip by Martin to consider Advanced Factors, thanks.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35622 ![]() ![]() |
re your disc question Ryan, i've always been told its best to replace the discs when fitting new pads unless the discs are in very good condition..
Quote Stan "... i quite fancy the drilled and grooved type.."
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
I run drilled & grooved Mintex disks with OE pads and they are great... Downside is they warp easily so you have to be carefull putting heat cycles through them to start with, then it's a case of breaking heavily to clear any warping (I think they are softer then standard disks)
I'll be playing it safe then with standard durable Brembo discs and brembo pads
Okay... if I order the genuine front Brembo Disc and pad set (Brembo calipers on the fronts anyway) from Adv Factors and fit them (properly) myself, will I be invalidating any part of my L.R warranty? |
I guess that is a question only your warrenty co and Adv Factors can answer? |
Checked LR warranty handbook
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Nothing👍
Just ordered these from site sponsor Advanced Factors. Really helpful and quick to reply to queries |
How's that for a quick and reliable service? Ordered the front Brembo brake kit from Advanced Factors yesterday and within 24 hours, a courier has just handed them to me, at the other end of the country!
that is good service, now you have to fit them.. |
