Home > Maintenance & Mods (L322) > Front ride height sensor
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Got the ' active suspension " fault message on the dash so borrowed a mates code reader and found it pointed towards the front right sensor. Crawled underneath to give it a squirt of WD40 but from the way it was hanging off the chassis , realised that wasn't going to cure it !!
Just a case of age I think so ordered a new one from Landrover Supermarket for £50 and set about replacing. EASY PEASEY !! Couple of screws , loosened with the help of Mr WD and new one on with in 15 mins and working !! Is there an easier job on the old FF ?
Post #236412 22nd Jan 2014 7:53am
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
Post #236467 22nd Jan 2014 11:53am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
An easier job to do....putting fuel in it.....mind its cost more to do! Twisted Evil
Good to know thats an easy one to sort Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #236480 22nd Jan 2014 12:26pm
And it doesn't need calibrating? Previously..
Post #236484 22nd Jan 2014 12:47pm
DaveK
Seems not. Car sitting perfectly on all four corners. Went to full height and down to entry with no problems.
Post #236486 22nd Jan 2014 12:52pm
Result Thumbs Up Previously..
Post #236491 22nd Jan 2014 1:36pm
And so it should for £50!
£50 for a height sensor? .
Post #236507 22nd Jan 2014 3:38pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Job I have to do soon as the arm attached to the suspension has a crack in it, I'll get round to it one day...
Post #236508 22nd Jan 2014 3:52pm
Height sensors are not plug and play, they have to be re-calibrated to the vehicle
Post #236548 22nd Jan 2014 9:23pm
SteveMFr
Site Sponsor
Exactly.
Height sensors are being manufactured to closer tolerances these days, so replacing a sensor w/o a calibration will not throw an immediate fault, but in the long term the suspension will constantly be readjusting to try to meet the demands of a sensor that is not calibrated properly.
In a best case that means a fault sometime (which will force a recalibration anyway) or in a worst case it means replacing worn components such as the compressor in the foreseeable future because they are overworked.
Doing a calibration is a 15 min procedure with practice, the first time it should only take an hour or so including reading up on what need to be done. And you need a diagnostic tool capable of preforming a recalibration.
You pays your money now or you pays more money later. Yawn
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #236588 23rd Jan 2014 8:48am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
my sensor failed last month..
easy to replace. 15 min job
but my trustworthy dealer explained why they needed to re-calibrate..30min job 2011 4.4 TdV8 Nara Bronze
Post #237193 26th Jan 2014 9:34am
