![]() | Home > Technical (L322) > So this cold blast in the USA. |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
-25 to -30 C no problem in Norway any lower and I usually keep it running til I return in a warm garage
As you should be ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Them Yanks Tanks have block heaters they plug into the mains |
Problem in the US is they lack an FBH unless specc'd. A good old TD6/TDV8 has this function which makes life much better when used remotely. Also the Antifreeze mix should be a bit sronger, ideally more like 75% in extreme cases.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I worked in Grand Rapids for a couple of weeks a few years ago and they did'nt switch the diesel engined trucks off at night as they feared they would not start once the oil had got down to about -30.
Previous car, Discovery, I had a Kenlowe electric engine preheater fitted connected to the mains electric thro a time switch.
I've thought about getting one of those for my VX220 which I normally commute in. It is garaged, but it would still be nice to get in a warm car. I also hear that on cold days they can really improve the fuel consumption as the engine starts warm. |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Just about everything in the universe is.... ![]() ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
Graham, you are excluded frome these discussions. You were burnt. |
vallef Member Since: 03 Apr 2012 Location: Stockholm Posts: 10 ![]() ![]() ![]() |
OK this just came up in another forum so my answer is below. But some high level points.
Interesting |
No, not done that but i do see a lot of cars in sweden during the winter which put some cardboard or similar in front of the fan or radiator. At the front of the radiator of the TD6 there are some flaps which i assume only allow extra air (cold) through when The car is moving.
