![]() | Home > Maintenance & Mods (L322) > rear disc change TDV8 |
I know how to change fronts but with EPD is there any special instructions in changing the rear discs. Havent changed discs before only pads so need a little guidance please wiki only shows how to do fronts . Thanks |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Pretty much the same as fronts, but you have the handbrake components to deal with so a bit more tricky. There is an inspection hole and plastic bung that you have to line up to release the handbrake shoes. Its quite easy once you have it lined up. From memory its at 6 oclock on the disk / drum face. |
Thanks chaps I was waiting for you to do yours Mark |
