Home > Technical (L322) > Open door error - HELP!
RR2008HSE
Hi All,
I've just had the car in to a body shop. There was a very minor hit to the front passenger (LHD) corner. They polished some marks on the headlight, removed and repainted the front bumper and painted the front fender. The car looks great.
However, on the (long) drive home, the car gave out an error message I've not seen before: "CLOSE DOORS TO CHANGE HEIGHT." (Only displayed when I tried to change height - I was just checking everything was normal when I was stopped at the traffic lights.) I stopped twice to make sure all the doors were closed (incl. tailgate) The fault remained, even after I stopped for a bit to run some errands.
Any ideas? Is there something that could have been disturbed or not plugged back in?
It's really frustrating after waiting ages for the repair. Any help would be appreciated. Thanks.
Bow down
Post #225834 29th Nov 2013 3:43am
paneldamage
Strange, cos if the door lock sensor is not detecting the door is fully closed, it would show by the courtesy lights being on, I would start with the multiplugs on the drivers door outstation, have a really close look at the connectors and don't assume they are making a good connection - I had this on mine and it was one of the pins.
Post #226044 29th Nov 2013 10:30pm
maybe a phone call to the repairers and ask how they actually did the job and that might give you a clue where to look... ... - .- -.
Post #226045 29th Nov 2013 10:34pm
RR2008HSE
Stan - very sensible suggestion! I'm already on that.
Paneldamage
No, the courtesy light is NOT on. I tried opening a door while moving and got a DOOR OPEN warning. This issue is NOT generating that.
Post #226085 30th Nov 2013 1:31am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Would a problem with the bonnet sensor cause an open door warning? 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #226096 30th Nov 2013 8:54am
RR2008HSE
Hmm. It can't hurt to try. Slammed all the doors, but I didn't think to check the bonnet. It's easy to check. Thanks! Bow down
Any other suggestions?
Post #226206 30th Nov 2013 8:27pm
did you find a solution to this?
Post #235295 16th Jan 2014 1:50pm
RR2008HSE
Sort of. The next day the error was gone. It hasn't reappeared. I don't know why. As long as it doesn't come back, I'm happy. Shocked
Post #235321 16th Jan 2014 3:14pm
nice and simple repair then.. Laughing Thumbs Up
Post #235335 16th Jan 2014 4:24pm
RR2008HSE
Well, it's a repair that matches my skill level.
I didn't want to say anything in case the car remembered and started the warnings all over again. Shocked
Post #235449 17th Jan 2014 2:22am
The car has several micro switches in the door latch... Separate micro switches for the CL and for the Alarm... If it ever comes back, simply unplug and plug in all the plugs to the latch, get a screwdriver and latch the door (so it thinks it's closed) then you can check it all works Thumbs Up
If all else fails, it maybe needs the latch mech replacing (they fail quite often) quite simple Thumbs Up
Post #235467 17th Jan 2014 8:31am
RR2008HSE
Thanks CTCraig. Much appreciated. I've noted that in case it reappears! Bow down
Post #235786 18th Jan 2014 11:40pm
Post #235819 19th Jan 2014 11:30am
