![]() | Home > General > Trying my first FF |
Take your time you CAN buy a very good Range Rover for under £10k and there is no reason it should cost you more than any other older premium car to run. Well serviced higher mileage is fine.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
The early 5 speeds, but there are plenty of us who have not had an issue.
Its the BMW V8 I am talking about! In the 2004/5 Hybrid car. It had the Flat front but with new style Touchscreen NAV etc but BMW V8 Engine and no reversing camera. Its this particular car I think is good value and seem to me to be reliable being the last of the BMW cars. |
And when you get that BMW V8 put on a K&N Cone Air Filter it sounds great and lets the V8 Breath easily |
RogDen Member Since: 29 Jan 2013 Location: Somerset Posts: 7 ![]() ![]() |
If I raise my budget a bit you mean something like this http://www.topmarques.co.uk/classified/adv...rchad/Used Roger The lunatic is in my head, You locked the door, threw away the key Theres Someone in my Head, its not Me. |
Yes that the car although the one in link has been modified a bit more than I would be happy with. Look for a stock standard factory as you can find. Bits can be removed however.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I'm with Gazellio on this one. I had a 4.4 on a 54 plate that had the touchscreen and I had it for a couple of years and I can't fault it. The engine is bullet proof - It did have some cam chain issues - but with that mileage I doubt if there's any trouble looming.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
Just a add on to the OP's last advert - £12 k WILL get you a Jag engined car - although there are less to choose from. Indeed, there appear to be more SC cars available than those with the 4.4 NA engine. I had to look hard & travel to get mine. If it's an option to you, I'd hang on for a Jag car - good luck with the search !
rich89 Member Since: 05 May 2013 Location: United Kingdom Posts: 295 ![]() ![]() ![]() |
K&N cone air filter??? Hmmm Easy to change? |
sam-mubarak Member Since: 08 Feb 2014 Location: Lancashire Posts: 4 ![]() ![]() |
Hi, I sold my p38 4.6 hse a few years back, to start my own business and fund a van. Im now in the situation to buy another range rover.
The hybrid will have a totally flat front bumper, below the headlights across. Just like mine in my avatar. It will have wipers on the lights if xenon a. It will have a touch screen sat nav.
Thanks for the reply, so it has the 02-05 front end, but the later touchscreen fitted? Sounds great to me, I prefer a before 05 car so its in the cheaper tax bracket and bmw engined, and i could always do a 2005> front end conversion, Thanks, Sam |
Exactly. Obviously if it's not a model that has the sat nav, it won't have the touchscreen. The speaker grilles are also different, and have like a circle in the middle of the grille.
Thanks for the info, yeah I'm definitely after a vogue, if I ever buy a car I always want decent spec levels, otherwise I always regret it, Sam |
