![]() | Home > Technical (L322) > Mirror Glass Replacement |
hi, easy...if its craked..i have a set of the plastic trim tools and used the small lever at the bottom of the glass,it will pop off, remember from the bottom of the glass. if its a pre 05 you can change the puddle light as well V8 facelift Range Rover Autobiography 22" wheels.
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
Glass not cheap though |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
i bet you would be surprized to the cost of new door handles...i was |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
the reflector in the rear bumper is expensive too 2002 td6 vogue, 06 supercharged facelift
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
If it helps, there is a round sort of plastic clip thing on the back of the glass that the internals pop into (motorised bit etc)
pre 05 is the same as a bmw x5 if that helps 2002 td6 vogue, 06 supercharged facelift
