![]() | Home > Technical (L322) > Autologic error codes |
| jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44
To me it looks like a cascade effect due to signal Los of data bus network.
| ppcsl Member Since: 12 Sep 2012 Location: Ellon, Aberdeenshire Posts: 107
Thanks for the reply Jak, yes that would make sense. If something in the loop of the fibre optic feed is faulty then the light doesn't get to anything else. I have bought a replacement amp to try initially so hopefully it is at that point the signal is interupted. Hopefully there will be no rain or snow at the weekend so I can get it tried. I don't fancy trying to debug the fibre fault, I should have brought my fibre tester home from work. |
| All times are GMT |
