![]() | Home > Technical (L322) > Burning smell |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Have you checked your exhaust for leaks? That is quite a common reason for smells coming in the window. Previously..
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
I havent but it doesnt sound as if its blowing, also its more of a rubber burnt smell than an exhaust smell.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
After a run feel each of the wheels and make sure that none of them are hot.
Ive felt the wheel centres and they are cold, there is a lot of spoke areas on its wheels so not a lot to touch.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
You could do no wrong by warming up the car and taking it to kwikfit for a tyre /brake check, as you think there is a smell, -a second opinion, with car in the air could lead you to a smell etc. perhaps ask if it can go round the block and straight onto the ramp. -their safety check is free, and you might ask if you could go under the car with the guy etc. it could leads you to the source. you are not obliged to have tyres replaced at this point etc. -and the spotty faced kid would jump at the chance of ogling your SC! ask him if any fluid weeps staining exhaust etc. |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
Automatic gearbox okay ?
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
I'd go for rear caliper seized - very common on your year of car with TRW calipers. I've had it on both I've owned - both '06 MY cars.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
if you've had your transmission rebuilt recently then i suspect there's an oil leak causing the smell...take it back to whoever done the job and ask them nicely to stick it on the ramp and have a look underneath.. |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Drove my SC quite 'briskly' at 3am the other morning whilst taking a sick relative to A&E
Hi Glynn,
Thanks for all the replies.
I'm definetely thinking it's a rear brake issue, it has Brembo brakes.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Wiki wiki wiki |
