Home > Technical (L322) > Rear seat won't unlatch to fold down
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
The right hand rear seat (single one) won't unlatch to put it into a folded position. The activator on the shoulder will move (so you can see the red warning indictor that the rear seat is unlatched) but the seat won't move. It is just stuck. The other (double width) side works perfectly.
I had this once before (about 14 months ago) and sent it off to the dealer.
I put the seat down once in a blue moon but I'd like to know that it is safe.
Is there a way of freeing it myself and somehow "resetting" the mechanism, or is it a trip to the dealer?
Post #23456 28th Jul 2010 8:43am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Just looked at how my seat latch operates....
The release lever or 'activator' with the red indicator is connected to the upper catch by a metal rod which pulls the upper catch ^ up when you pull the latch to fold the seat - the lever has a spring tension to it - when the upper catch is pulled up, this allows the lower catch to move, which then allows the seat back to move forward (by releasing the lower catch from the anchor bar)
Confused What I am trying to say is - has the metal rod become detached from the upper catch? (the metal rod is secured to the upper latch with a circlip) - if the lever still has the spring tension, you may not notice if the metal rod has come adrift.
It looks as though you should be able climb into the boot area of your car and (by using a small screwdriver) release the upper catch and therefore allow the seat to move - so as you would be able to get a better view of the latch area and see if the bar is still connected.
Has this helped ? - Neutral Maybe... - Confused ? - Rolling Eyes More than likely!
Whistle I tried to help...
Post #23510 28th Jul 2010 12:26pm
Emperor Mong
I think I understand. I'll take a look at the weekend and see if I can do it.
Post #23516 28th Jul 2010 1:17pm
