Home > Technical (L322) > Using IIDTool Pro BT to Read Transmission Temperature
blueRR2006
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Hello Everyone,
There was a post on Jun 14, 2013:
transmission oil temperature:
Need to get idea of temp of new oil in Gm box as part of refilling process. Have an IIDTool but can't see anything for getting a reading. Is there a neat way of establishing when oil is at right temp?
I didn't find any responses.
How accurate is the Transmission temperature reading on an iPad/Android display or RR display?
When I change my Transmission filter/oil, the temperature has to be read at a specific point for expansion purposes. I want to be able to use the display (s) reading vs using an IR Thermal gun temp readings. Land Rover dealerships use the T4 to measure temp, so in theroy, the IIDToolPro BT should do the same, correct?
Thanks
blueRR2006
Post #234629 13th Jan 2014 8:53pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
So far I only have found it in the live values but don't now how accurate they are.
Post #234635 13th Jan 2014 9:11pm
ppcsl
Scotland 2005 Range Rover Autobiography Td6 Java Black
Hi bluerr, lidl are selling one of those infrared temperature probs. You just point the beam at where you want to check the temp and it it comes up in an led readout. Only £17.99. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #234672 13th Jan 2014 11:48pm
blueRR2006
ppcsl,
Thanks for the info but I already have one. Thumbs Up
what I want to do is be able to view the transmission temperature via bluetooth on an iPad/Android tablet. Smile
Post #234677 14th Jan 2014 12:51am
you can do this with an IIDTool....
Post #234710 14th Jan 2014 8:37am
SteveMFr
Site Sponsor
Hi blue,
We read off the same sensors that the T4 does, so the accuracy is the same as the dealers get.
While I really don't expect that you need to be accurate down to the degree, I have read (somewhere) that using an IR thermometer gave a reading that was considerably different than the reading on a diagnostic system. Then again, I've done ATF changes using an IR thermometer...
HTH
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #234754 14th Jan 2014 11:30am
blueRR2006
Cool what I wanted to hear Thumbs Up
Post #234933 14th Jan 2014 8:27pm
ppcsl
Dooh !! just noticed you are in the USA, I could have posted it to you. Laughing Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #235000 14th Jan 2014 10:51pm
ppcsl
There was a thing on the gadget show on UK TV, it is below.
http://gadgetshow.channel5.com/gadgets/iobd2
Dunno if it will do it. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #235002 14th Jan 2014 10:59pm
blueRR2006
thanks a cool little tool!! Laughing
I love technology.
Oh and by the way I JUST ORDERED MY IIDTOOLPRO BT #DA6412 from Island4x4!!!!
Yes!!! Mr. Green Mr. Green
Post #235013 14th Jan 2014 11:47pm
if you put your FF details into the drop down menu here,
http://www.gap-diagnostic.com/products/iidtool.html it will show what you can do with the IIDtool..
Post #235037 15th Jan 2014 9:31am
