Home > Wheels & Tyres > inside wear on rear tyres on 22 inch wheels - 02 TD6 |
redshovel Member Since: 11 Jun 2010 Location: Belfast Posts: 244 |
I had mine on 22s for a time.......utter nightmare....and I never towed once. I won't bore you with my tale of woe but unless ur alloy wheels are genuine Overfinch etc coupled with good tyres - you have little chance of ever getting peace. Even then it's a consent battle making sure everything stays aligned.
13th Jan 2014 8:27am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7834 |
19s are the biggest land rover recommend for the td6. 20's are listed as not an option in the accessory brochure, so whilst they should be fine, they were never available for that vintage.
13th Jan 2014 6:54pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2660 |
Mine were very bad for inside wear until I got the alignment done properly. |
13th Jan 2014 7:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Alignment is the key |
13th Jan 2014 11:26pm |
