Home > Technical (L322) > Heated driver's seat
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Sorry, just remembered, the seat back connector is tucked up through into the seat back itself.
You have to remove the seat back to get to it.
To remove the seat back first unhook the leather flap that's tucked under the bottom of the seat (on elastic hooks).
If I remember correctly the seat back itself is held on by two Torx screws, one in each bottom corner screwed vertically upwards underneath. The seat back should then pull upwards if you prise the bottom out first (the top is held in by plastic vertical slots so don't pull it any other way!).
I don't think you need to remove the arm rest, it slots around it but check before man handling it!
With the seat back off you can narrow down the faulty elements further by checking each one. Given the age there may be more than one faulty element but as previously mentioned if the seat base doesn't work there's no point carrying on so worth checking that first.
Post #234401 12th Jan 2014 10:56pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Many thanks your a star wiill have a go later all worked before except one got really hot near the top on the left side that burnt a little by the seem Sad _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #234473 13th Jan 2014 10:50am
Scottyav
Sorry to be a plank but looked up for ages and can't see any screws with the flap back underneath it's driving me Censored nuts now Evil or Very Mad Evil or Very Mad Evil or Very Mad _____________________________________________________
Post #234479 13th Jan 2014 12:01pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Check out this thread, should be of help... http://www.fullfatrr.com/forum/topic17436-30.html
Post #234812 14th Jan 2014 2:24pm
Weejock
http://www.numcat.ru/landrover/p/41/50666/
2 x screws HM2
You might need to get your head right underneath to see them.
Post #235575 17th Jan 2014 6:21pm
Kes
England 2005 Range Rover Vogue SE Td6 Java Black
Hi
Got similar probs with heated drivers seat . Lights go on for 5 seconds , then go off , no heat .
Checked forum to find problem lies in heater pad under seat.
First check all wires for continuity .
Raised seat to access wires , wiggled a few , and hey presto , all working
I can't believe the driving position is so much better , feel even higher than ever ?
Thanks for forum knowledge , mine just a glitch
Will double check all connections , and lube accordingly !!!
Kes :
Post #292593 12th Nov 2014 8:47pm
