Home > Technical (L322) > Heated driver's seat |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
common problem, have a look here,
19th Dec 2013 4:42pm |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 212 |
Thanks Stan, just had a look at that but there's a load of info! I've had it tested and I know it's the element that's faulty, so is there anywhere I can get one that's not going to cost me an arm and a leg? |
19th Dec 2013 4:52pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Hi Squirrel
19th Dec 2013 6:29pm |
Hi Googsy,
19th Dec 2013 8:14pm |
Depends how big your bum is I suppose
19th Dec 2013 8:25pm |
It's not big enough to require thermals costing in excess of £2000. I hope.
20th Dec 2013 6:31pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
There's an LTB about the steering wheel issue. Typically a motor going Pete Tong.
20th Dec 2013 8:05pm |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
Hi my 03 drivers seat has got hot on the left side and heated close to the top and seems like it's burning hot can you unplug the base swab so the back still works or can you join the unplugged end to make the rest of the seat heat except on one side? _____________________________________________________
10th Jan 2014 10:27am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
You can run a seat with less than the normal number of elements but, as you say, if you unplug an element you need to then close the circuit as all the elements on the pre facelift RR (<2005) are in series. If one goes open circuit none of the elements on that seat will work.
11th Jan 2014 1:51pm |
On the base swab where are the connectors to go to the three elements to disconnect I've lifted the side up a bit to see the burn does the seat have to come out? _____________________________________________________
11th Jan 2014 6:56pm |
The seat base element connectors are under the seat base, you don't have to remove the seat to get to them.
12th Jan 2014 1:05am |
Cut the black and grey wire and joined them up but now the dash light stays on five seconds then goes off now ? The left side has burnt the swab so tried to bypass that side any ideas thanks. _____________________________________________________
12th Jan 2014 4:41pm |
If the light goes out after 5 seconds then it sounds like you have an open circuit, the same error I was getting.
12th Jan 2014 6:52pm |
Tried to get to the three with half the cover folded back but can't feel any are they under the foam or under the cover top even tried from rear back but no joy _____________________________________________________
12th Jan 2014 9:14pm |
