Home > Maintenance & Mods (L322) > Power steering hardat slow speed
Jason1608
Hi all got a 2006 tdv8 steering has started playing up can't turn it at slow speed and makes noise when turning it, turns ok ish at speed but still make noise got a servotronic valve being put on tomorrow, did note when I change power steering fliuld in was sludgey at the bottom any thoughts anyone.
Post #233489 7th Jan 2014 10:22pm
the servotronic valve seems the likely cause..its a process of elimination so hopefully replacing the valve will solve your problem..
Post #233496 7th Jan 2014 10:55pm
Jason1608
Was not the servotronic valve so I am going to new pump on it see what happens .
Post #233643 8th Jan 2014 9:53pm
i would have betted on the valve, lets now hope the new pump will solve it..
Post #233714 9th Jan 2014 9:10am
MY Indy says BCU is most common failure but this does sound like pump.
Post #233718 9th Jan 2014 9:26am
